andyp
Hi,
My Isotherm ASU 3701 fridge will not power up.
Last time this was corrosion on the thin RJ11 socket contacts which link to the ASU control panel. This time it seems more fundamental.
There is +12.7V at the main connections from the supply breaker to the control unit (terminal strip at bottom of the picture) but no sign of life on the three coloured LEDs on the control panel.
The Control Unit mounted on the side of the compressor does not have the T, C, P connections mentioned elsewhere, it just has a three pin connector direct to the compressor, a fan connection and remote RJ11/RJ9 socket connections to control panel and thermostat.
The Control Unit is mostly a heatsink for a number of power transistors (picture attached).
Any ideas on what to check first or where to get a spare?
