Jokani
My 26ft Centaur currently has 8mm galvanised anchor chain, but the chain jams when the pile reaches the top of the locker, to free it I need to go down below in to the forpeak and adjust the chain before I can start the windlass again. This is OK with crew on board but I more that often sail single handed, and leaving the cockpit is often not an option.
In an attempt to cure the piling problem I was going to swap the gypsy from 8mm to 7mm and source 7mm stainless chain. But Jimmy Green cannot supply 7mm stainless chain and the only other source I can find is http://www.tecni-cable.co.uk/7mm-x-22mm-x-23mm-A4-AISI-316-Stainless-Steel-Chain-MBL-2500kgs-208.300.407 this is not specifically for marine use, but the loads look similar to galvanised chain. Is it suitable?
I could possibly move to 6mm, but that could be undesized for a Centaur in a blow?
