is this diesel too big for my Crabber
aitchw
18 Feb 2002
West Yorkshire, UK
I notice it's a Sulzer partnership. They have had deals with many famous heavy engineering companies over the years including some UK ones like Davy.
Very impressive bit of work.
Johnjo
8 Sep 2002
Its the perfect size for your boat, but before you condsidering purchasing one.
I would check you have enough room to swing the prop as if its to close to the hull it will effect performance !
All joking aside " its a pretty awsome lump "
sailorman
21 May 2003
Here or thertemp ashore
u may well req a slightly larger fuel tank with an emersion heater in it /forums/images/graemlins/wink.gif /forums/images/graemlins/wink.gif /forums/images/graemlins/wink.gif
Johnjo
8 Sep 2002
Will this enhance its cold starting qualities ?
snowleopard
Oxford
It would certainly make your boat go, though I suspect the prop would stay still and the boat would rotate. Wow, what a ride!
oldharry
30 May 2001
Might affect the handling quite a bit - vertical acceleration is likely to be better than horizontal - like downwards. You will notice some increase in draft too.
You might also have to move the engine beds quite along way.
Sybarite
7 Dec 2002
France
Is there an outboard version?
102000 hp yet it can only turn the prop over at 102 rpm. Just think how it would move if you could get it turning at 3000 rpm like any good marine engine...
John
ashanta
28 Apr 2003
I want to know if you can hand start it? Modern engines today just don't seem to come with a starting handle!
regards.
peter
