demonboy
... my satellite phone aerial? It certainly makes the job easier to install than mounting it on a s/s plate on the pushpit as I can feed the cable through the inside drain hole. Just concerned about the amount of water that could hit it and rip it off. Because it is behind the vent box it would get more protection than if mounted on the front.
If I epoxy and/or sikaflex it to the vent box and use self-tapping bolts, do you think this would be ok? The vent box is approx. 7mm thick fibreglass. What type of self-tapping screws should I use? I can't get to the inside to bolt it on.
Any help appreciated.
