sailorbaz
Not wishing to hijack the engine bay fan thread - on which I've read about the huge amounts of air Diesel engines suck in, I went to the boat today and my 1GM10 has the standard air filter so all this air has to go in through a tube with an intake hole about 1" diameter! My engine is boxed in with fairly close fitting ply with insulation on the inside. It's open to the bilges at the front end but they are closed off with those round plastic screw on covers, so the only obvious air inlet is the hole for the starting handle which is about the same size as the air intake.
Is it enough?
Sailorbaz
Is it enough?
Sailorbaz
