Colvic Watson
The transom on my Halcyon 23 has a decent rake to it and unfortunately the combined exhaust/water coolant pipe emerges there. This means that to check there is any water running through the engine I have to lie down and lean well out - fine for a Marina start-up but no way is it safe when under way! What can I install to monitor the water flow as I understand that even a brief period of water coolant block can result in an engine rebuild - and dangerous seizure of the engine.
The engine is a Yanmar 1GM with no engine temp gauge (would be too slow to react in time anyway?)
Thanks!
Thanks!
