Richard10002
The rules make it quite clear that, even if you are the "stand on" vessel, as soon as it becomes clear that a collision cannot be avoided by the actions of the give way vessel alone, you are obliged to take action to avoid a collision.
If the OP has decided that he is the stand on vessel, he must stand on. If the situation is such that he decides that he was wrong, (e.g. The other boat is a fishing vessel), he becomes the give way vessel, and must give way. If he remains convinced that he is the stand on vessel, but a collision cannot be avoided by the other vessels actions alone, he must take action.
I could suggest that, if you are close enough to be reasonably sure that there is no one at the wheel of the other vessel, you are in the region where actions of the other vessel won't be enough to avoid a collision. The things that make you "reasonably sure" are for you to decide. Two crew dealing with nets, and an erratic course, might be sufficient. Add fishing shapes and/or lights, merely serve to add fuel, whether actually fishing or not.
So... Whatever the case with the other vessel in the OP, the rules are fairly clear as to what can/should be done.
