Burnham Bob
I have to bolt on my new locker lids. I want to cut the bolts attaching the hinges to the lids off almost flush with the nuts underneath. I can't get a hacksaw - even a junior one - on properly once the nuts are fastened as the angle is wrong. I know i could put a bolt on, measure it and take the other bolts home to hacksaw to the same length but as I've got the cordless drill there to drill the holes in the lids, the ideal solution would be a rotating cutter disc like a dremel one that fits an ordinary drill. Does such a thing exist? I'm assuming that the cutter would be at right angles to the chuck and would not have too large a front boss. Am I lusting after the unobtainable?
Mind you what's your opinion of using brass screws? The lids are 18mm marine ply. I know that with bolts the load is spread on the penny washers underneath and the heads of the machine screws in the countersunk hinge holes so the bolts can't strip out of the holes if the lid is a little uneven in the way it fits and a load is put on it when you step on the lid. Would screws hold in the Forum's opinion? Most hinges take an M5 bolt but the replacement hinge has M3 holes.
