Burnham Bob
I have a leisure battery that runs things like the water pump on the pressurised system so the pump needs to have some oomph to pressurise the system. When the pump kicks in, the voltmeter dips from 12.5 - ish volts to maybe just 12 volts - you can see the needle swing down. So under load it's not delivering the same voltage as at rest. The battery was charged before going back into service. If the voltage is falling when a load is applied is the battery on the way out?
