dauntlessman
Hello people,
Recently my engine has been riddled with problems. Last time it was fuel (starvation) problems, which you guys kindly helped me out with and I have since replaced the tank.
The engine is a (very old) Renault diesel, single cylinder, 8 HP unit.
Anyway I took her out for her test up the river Fal and what had started out as good - soon turned bad. Though I am now convinced that the fuel starvation problems have been remedied, what looks to be a much more serious issue has taken hold.
With the engine running at idle (out of gear), it sounds relatively smooth with no major smoke or unusual noises and cooling water running nicely through the stern exhaust. If I put it into gear it chugs along reasonably well but only at very low throttle.
As soon as I give it any kind of throttle (to get her moving quicker than approx 1.5 knots), I have seen pretty substantial amounts of black smoke pouring out of the exhaust! Presumably this indicates a substantial amount of oil being burnt. Note that this only at higher RPM.
Unless you guys can make my day and come up with a reasonable explanation for this, I reckon it’s knackered and I’m not sure if it’s worth getting fixed. Spending any more than a couple of hundred just seems a bit of a waste given it’s age etc.
We continued our little jaunt using my Honda 2 HP outboard, which actually pushed her along quite well given that she, weighs a couple of tonnes. I’m not to sure about this as a permanent measure and it’s pretty clear that this is not a very economical way of covering larger distances.
Any advice on either the options for the inboard or the effectiveness of my little 2 HP would be gratefully received. I’ll be floating about for Falmouth week anyway so I guess that will put the outboard through its paces!
