Is it possible to have too many anodes??
tcm
11 Jan 2002
Caribbean at the moment
Changed the anodes and got the man to put on an isolation transformer ££ ugh.
My shaft anodes are not replaceable with scuba dive so i want to extend their life as long as poss...lifting the boat only possible in super-wide lifts.
So a hanging anode in adition to existing anodes becomes attractive when leaving boat for long periods in marinas.......but now as per question, a leetle frenchman in the pub last night told me maybe eet will be to murch anodes and ze reverse will hapen, hein? in other words, he indicated that too much anodery is as bad as too little. Is this bollox? Ithink it is. But dunno?
Any further info appreciated.
ccscott49
7 Sep 2001
I have heard of "over anoding", but only on wooden boats, but I think it's bollox as well. So anybody with better knowledge, I'd be interested as well.
lookout
28 Aug 2003
ahh, recently chatted to nice english man at anode-makers in Faversham- who backed up what I'd read before, that only issue was possibly gassing at the surface of the metal being protected- Chemists don't bust me - just reporting was was said/read.
Soo, with a painted steel boat & anodes hanging like bananas- maybe the bubbles push the badly applied paint off? ( some 'evidence' of this on mine, for sure ) but otherwise no probs.
Of course this time I bought bigger anodes thinking the 2kg ones only just manage 2 years afloat, and out the water find the old ones still very useable for another year if needed; but new ones went on anyhow, since expensive anodes actually aren't expensive at all when bought direct from the foundry here , super chaps even mod'd a standard unit with longer mountings & custom slots to fit the boat at no extra cost.
edit - yes, Englander, I'd read of it softening the timber around the anodes on woody boats
Porthandbuoy
27 Apr 2003
The Gareloch
www.backbearing.com
Er. I think it's around the noble metals you're trying to protect where the wood suffers.
boatmike
30 Jun 2002
Solent
Absolutely. Really terrible to have too many anodes... It will seriously upset your stability, the area under the z curve will be affected and your boat will sink.
18 May 2003
Med
I think you would have to have an orfull lot out before any adverse effect was noticed if any. hanging one over the side may not draw away from the shaft ones, it will aways seek its shortest path, and in line of sight, so Me thinks your shaft ones still take the brunt of it, but ounce they become a bit sad the hanging one should take over bit by bit
lookout
28 Aug 2003
well yes, quite possibly, or not, I have no idea which way round it was really, just that it went soft, ooer.
D'you know how that happens, in seriousness?
Porthandbuoy
27 Apr 2003
The Gareloch
www.backbearing.com
I think it's electrochemical decomposition of the cellulose fibers, or the lignum cell walls, or both, or something entirely different. Er, don't know really.
Any chemists out there??? /forums/images/graemlins/confused.gif
VicS
13 Jul 2002
[/ QUOTE ] Well I still remember a little but you can read all about it in one of MGDuff's technical documents Here
I would object to the bit that says "In this process, known as “Hydrolysis”, water is ‘broken down’ into its component parts of hydrogen and oxygen. The liberation of hydrogen at the cathode results in an increased level of alkalinity
It is true that an increase in alkalinity (and pH) occurs but perhaps not quite by that mechanism.
huldah
31 May 2004
Bath UK
Wow. I have two magnesium anodes hanging at the rear of the boat to protect the steel rudder. The lower bearing and frame are bolted into the oak keel.
Do I leave them or remove them?
Philip
huldah
31 May 2004
Bath UK
Re: Is it possible to have too many anodes?? [Re: Mariposa]
Thanks, I feel better already. Yes, you are right, she is moored in fresh water. I knew anodes are often not recommended for wooden boats, but I did not know how the damage occurred.
Philip
VicS
13 Jul 2002
[/ QUOTE ] Probably leave them but inspect the timber around the bottom bearing and frame. Remove them if any trouble is suspected.
How are your anodes connected to the rudder? Via the tiller or via the bearings. Is the connection really all that good?
I wonder if it would be better to fit anodes directly to the steel rudder. It would improve the protection of the rudder provided it did not lead to over protection lifting the paint off.
Stoaty
7 Oct 2004
Medway
In practice the breaking down of <u>sea water</u> will also produce Chlorine and Sodium Hydroxide. Perhaps this is where the increased level of alkalinity comes from.
VicS
13 Jul 2002
In practice the breaking down of sea water will also produce Chlorine and Sodium Hydroxide
[/ QUOTE ] Precisely. The cations, sodium, calcium etc migrate towards the cathode (the items being protected) that leads to a rise in pH, (yes sodium hydroxide aka caustic soda is produced), the deposition of calcium carbonate and the release of a little hydrogen. The anions, sulphate, chloride etc migrate towards the anode. That leads to the release of oxygen and chlorine and a fall in pH and the dissolution of the anode. I'd expect very little free chlorine to be actually released and little oxygen either as the main result will be the dissolution of the anode.
Stoaty
7 Oct 2004
Medway
I think you may be surprised about how much chlorine is given off. This reaction when sea water gets into the battery compartment of a submarine can incapacitate a crew very quickly.
PM me if you would like a simple home experiment to create your own chlorine and sodium hydroxide.
VicS
13 Jul 2002
[/ QUOTE ] Oh I know that you can produce a lot of chlorine from salt water by electrolysis. I've done it often enough on a small scale. In fact a current of 1 amp will potentially produce 0.13 cc of chlorine gas per second (please free free to check my arithmetic though) However in the context of cathodic protection by sacrificial anodes the currents involved are very small and since chlorine is fairly soluble and the water is moving one would not expect free chlorine gas to be evolved, it would be swept away as a hypochlorite solution at the very least
Generally speaking though in electrolysis deposition or evolution of an element at an electrode is the last thing that is likely to happen after reacting with the electrode and reacting with the electrolyte. In the case of zinc electrodes they will be attacked to form zinc chloride and since sea water contains high concentrations of sulphates zinc sulphate will also be formed. These are basically the mechanisms by which metal is lost from sacrificial anodes.
