capnsensible
Doubt if many cruising boats use a Cunningham.
I doubt if any do! Must be at least ten years since I've seen one on any yacht......
Main problem IMO, is the attitude of the boom before furling.
Get it wrong & you get creases in the furl & subsequent jamming.
I'm not at all sure why the attitude (presumably height) of the boom should be important, since the sail is not directly attached to the boom. I can only speak for my own, where it is loose-footed, and the clew has a sheave through which runs the double purchase outhaul. Other systems may be exist where the height matters, but it makes no difference with mine.
I'm really looking forward to this season-our sails have just come back from a tune up at Elvestroms and we have new vertical battens.
Bring it on!
I've never used a in mast furler, I just don't like the idea. They probably function well most of the time but I just don't want to run the risk of it ever jamming. I could live with in boom, as I could still drop the sail with a jammed furler.
I don't go for single line reefing either:dread:
I've long tbought about vertical batterns and adding more roach but been too nervous to try iit. Wondered if it increases risk of jamming when furled.
Very interested to know more, and see some pics if you get chance to post some.
Rotrax - I suspect and hope you will love the vertical battens - it makes a big difference.
Actually with the height of the boom mine also has the outhaul attached to a car and block that runs on the boom and is therefore loose footed. However when I have adjusted the boom height using the hydraulic strutt, I have found the sail tended to crease more. This could just be because the delivery angle has changed although thinking about it I cant see why this would make a difference. It is not something however I have really experimented with because I know the angle I set the boom at and if it has changed for any reason tend to set it roughly in the same position and everything has always been fine.
Yep!As suggested by the OP. Irrational.
I'll see what I can do.
Our SP Cruiser has the OE, but little used sails without much roach.
They had batten pockets but they were empty.
We are coming your way on our way to Cork next month-I'll PM you-you can see for yourself perhaps.
Interesting - I don't believe there are any batten pockets on ours, must be an SP thing. Did you get Elvstrom to make a new sail is it a mod to the original?
Yes, do let me know when you're close by, would be good to meet up.
