philmarks
OK, I was looking for Iridium, couldn't be a###d with time and expense to obtain LRC. Ended up buying a 2nd hand mini M transportable (not the marine version with stabilised aerial). All for £250. Ok call time $1.49 a minute and only 2400kbps data channel (9pin RS232 so will probably need serial to USB converter, laptop has XP Prof), but also has fax channel. Works fine (from car so far), have worked through the Saildocs site for gribs viewers etc; BUT, I'm stuck on one thing, help appreciated:
As far as I can work it out, I need to dial in to an ISP and retrieve emails with the GRIBS attached eg connecting via Outlook to a POP3 mailbox. I've also got some Venturi accelerator software which will hopefully speed up download, gribs only 7 or 8 Kb. Does anyone know of a suitable ISP. My regular home broadband ISP doesn't offer the low speeds I require!
At the end of the day I can get my Dad to send me weather faxes, but I'd rather sort out an independent routing, and have the email facility. Voice works great, crystal clear.
BTW also have Target HF3M which works OK-ish for weatherfax and Wetterdienst but quality is variable and for Tropics / Brazil I'm not expecting it to do the business. As other poster has said I have also have to turn off all the other electrical equipment aboard.
Thanks in advance for advice/help (hope I get some...)
