Inverter Danger
GrahamM376
30 Oct 2010
Swing mooring Faro
We've been having a lot of trouble with power outages in the yard, it was off all weekend. This morning, one of the yard employees isolated the supply to one section and the rest then had power OK. When he started investigating the isolated section, it was still live - some idiot had an inverter running without any isolation to his shore power deck socket and that's likely what had been causing the main RCD to trip.
Shore power and inverter should be switched so they can't both feed the circuit at the same time. If not, when the inverter is running, the shore power socket is live and could be fatal if fingers stuck in - think children or inquisitive crew.
You're quite right (nearly wrote dead right!). But is there a simple, cheap and readily available way to achieve that switching? And if so, how come it's not well known?
Or even a costly but practicable way?
Dererk
Not most, most just have one or two output sockets and an on/off switch. The Sterling and other makes I've had have no changeover switch.
OK, to satisfy you I've changed my post to read "many".
Edit: Oh, and I did mention "decent" inverters, I wasn't thinking of eBay specials. A number of modern Sterling inverters have an auto switch.
