mrplastic
I am fitting a 1kw PSW inverter to my beneteau 331 and am wiring it into the main supply box using a DPDT 30A
relay with a 12vdc coil. Shore power is supplied via the normally closed contacts and invertor output via the N/o contacts with the relay energised with a remote switch. My concern is the possible damage to the onboard battery charger. What if anything is likely to happen if the charger is supplied by the inverter output and resultant charging loop? Obviously this will consume more power than it outputs but is it likely to cause any damage?
Also, how do I address the earthing?
Any advice is appreciated
