Cerebus
I have learned from this forum that these devices need to be earthed as well as connected to an RCD type of thing available from caravan shops.
As far as I can make out from the posts I have read, the earth on a boat means a wire going from the inverter to a bolt (for example) through the hull and into the salty water (a “ water earth”).
Is that correct?
What about a caravan or camper van?
An earth can be used whilst stationary and on grass by ramming a rod into the ground and connecting the inverter’s earth connection.
An earth cannot be made easily whilst on the move though can it?
If parked upon concrete, I’d a wire laid upon the ground and a heavy stone or slab good enough?
Is that correct?
