slipknot
Can anyone offer any suggestions on where to start to look for a fix for my problem. I have had 2 occasions where I have pressed the power on button to power up the engine panel and seperate fuel gauge, and the fuel gauge only half reads and the panel does not power up (no inition lights, no hours reading, no starter when you press the start button) Had seastart look at it maybe 6 weeks ago, and whilst they saw the fault, tried a new module (ignition lights) it made no difference. After more tests it miraculously started working again and has done since, until today. Same fault.
I’ve removed the panel and get 12v to the power on off switch. When you turn on the power switch, in and out drops to 3v and nothing works of course. To make it even worse, I’ve just gone back to look at the panel to see that everything is now working exactly as it should. So clearly it works ok now, but it’s going to do it again, no doubt at the most inappropriate moment. Any suggestions what to look for. Is there an expert in Southampton I could call to come and take a look. Any advice appreciated?
