Kyle2
I have a problem with my raw-water cooled Volvo MD1B, which seems similar to problems described in other posts. The cooling water does not always flow when starting the engine at first, and also can stop sometimes when running the engine. The sea water strainer lid seems inadequately sealed at the moment, by a rather soft home-made disc of rubber, so I would like to eliminate this from the possible causes by sealing it properly to stop air leaking into the system. The water strainer is brass, approx. 3cm diameter, and incorporated with the sea-cock. Should the screw-on brass lid have a sealing ring or disc, and if so where could I get one to fit? Also, should sealant be applied to the screw threads? Thanks for any help that can be given on this.
