Interfacing a CP180 chart plotter?
20 Jun 2007
Live in Kent, boat in Canary Islands
www.bavariayacht.info
I've just bought a Standard Horizon CP180 chart plotter. It has 2 NMEA inputs and 3 outputs, and I first planned to connect them to a PC and other instruments as follows:
NMEA Common: PC DB9 Pin 5
Port 1 Input: PC DB9 Pin 3
Port 1 Output: PC DB9 Pin 2
Port 2 Input: See below
Port 2 Output: VHF + NavTex
Port 3 Output: Other instruments
Then it occurred to me that I may be able to feed the other instruments back into the spare input, and get the wind and depth gauges to talk to it.
Any thoughts?
Re: Interfacing a chart plotter?
Seatalk and NMEA are not compatible unless you buy the Raymarine seatalk to nmea converter which is very pricey. Some later raymarine instruments do have nmea also.
