tonybarebones
WHY TWO TIDES A DAY? If gravity is always pulling towards the moon, what causes the bulge on the opposite side of the earth?
Most people think the moon rotates round the earth. In reality, the earth and the moon rotate about a common centre just inside the earth's surface.
At the centre of the earth the two forces acting: gravity towards the moon and a rotational force away from the moon are perfectly in balance. They have to be otherwise the earth and moon would not stay in this orbit.
The 'tide-generating' force is the difference between these two forces. On the surface of the earth nearest the moon, gravity is greater than the rotational force, and so there is a net force towards the moon causing a bulge towards the moon.
On the opposite side of the earth, gravity is less as it is further from the moon, so the rotational force is dominant. Hence there is a net force away from the moon.
It is this that creates the second bulge away from the moon. On the surface of the earth, the horizontal tide generating forces are more important than the vertical forces in generating the tidal bulges. So there, now you know.
INTERESTING FACTS: When during a year can we expect to find the largest tides? A day or two after the full or new moon nearest to the equinoxes.
The spring equinox is usually the 21st March, and the autumn equinox, the 23rd September.
Some years have tides that are notably higher than other years. 1997 was a significant year, as will be the year 2015.
For really favourable conditions - you will have to wait around until the year 3182. Even then, the tides may only be 1 or 2 cm higher than in 1997. Well I never did... /forums/images/graemlins/grin.gif
