pmagowan
I have been researching this subject as an offshoot from the Northwest passage thread and would be interested in opinions. Most of the information online is about spray foam insulation on steel boats. My boats construction will be cold moulded wood and glass reinforced epoxy composite. So, on both the outside and inside of what will essentially be a wood core there will be glass reinforced epoxy. Since I am thinking this boat may be used in cold climates (colder even than ours) then insulation becomes a concern.
Big questions are;
What type of insulation?
Do you insulate under the waterline?
Windows, double glazed glass or plastic, thermally efficient frames?
Ventilation, is there any way to be heat efficient?
Water and fuel, do their tanks need insulated (mine will be integral to the structure)?
Also, heating would be of interest. I am already keen on a integrated system between an Ebby and the engine to provide hot water and hot air but I am wondering if a diesel or solid fuel stove would be wise as a backup or simply a nuisance.
I would be interested in your views and particularly in the pros and cons of covering up the inside of a cold moulded boat with insulation and thus hampering any visual clues to a failure of the epoxy layer.
Big questions are;
