thomashoebus
I installed a luxe panel for my engine volvo penta md 22 l.
At Volvo they told me that I only had to plug out the old and plug in the new panel.
That was correct without having to install senders for oil pressure temperature , battery tension,... Everything works and now I can monitor the engine on every vital point. But the temperature meter never rises over 60 °c, it should read 90. At Volvo they don't know the answer.
I checked with another (same model) temperature meter and that gave also 60°c. So it could be that the sender is not compatible.
Does anybody knows what's wrong here.
Or how many ohms I should read on the sender at the engine and how many loss there may be in the wiring to the panel?
Or perhaps at how many ohms the meter of the panel should give 90°c
Because I checked the temperature with a regular thermometer and that gave 90°c
If I Should know the correct ohm values for engine and meter at normal temperature I can pinpoint the problem after testing with the mulimeter.
Thomas
Thomas
