A
angelsson
Has anyone fitted an in hull transducer kit either ready made or put together themselves.
I have recently bought a clipper duet, complete with speed and depth transducers, the speed will fit into existing thru-hull ok, but the depth can be installed in 3 ways:
(i) The transducer face can be bonded directly to the inside of
the hull. (Some energy is lost to the hull but the loss in
performance is, for most G.R.P hulls, hardly noticeable).
(ii) A transom mount is available from your dealer.
(iii) The transducer can be positioned inside a G.R.P. hull by
means of an In Hull Transducer Kit.
I intend to use option 3, would appreciate any suggestions or help from those who have done so.
Also any comments on the other two methods of fitting.
Thank you
Thank you
