dmayes
As far as I am aware NMEA out will drive more than one device so you can connect say a GPS unit to both a tiller pilot NMEA in port and a DSC radio NMEA in port. Both should work and in theory you could possibly connect the GPS with up to 6 devices. However, you cannot connect two NMEA talkers together. So If I had an NMEA wind transducer I could not connect it to the previous tiller pilot as it would interfere with the existing GPS connection. Does anyone make a device that can receive the NMEA data from say a GPS, plus a digital compass and also a wind transducer, then combine all the sentences and output them in one go to all instruments that would benefit?
