Information required on stripping down a genoa furling gear
robert048
New Member
19 Nov 2006
My furling gear is becoming very stiff and I need to strip it down to regrease it. I can't seem to find a make on it so not sure where I can find the information I need would much appreciate if anyone could help. <span style="color:black"> </span> /forums/images/graemlins/confused.gif
Furling gear stiffness can be caused by several things, so before you get the grease out make sure you are solving the right problem.
Mine does not take grease anyway, but maybe somebody here will say that their's does.
My furling gear is becoming very stiff (cut):
Remove the sail & rope & see if the gear will rotate more easily. If it does, check your fairleads for the furling rope first!
Also check the rotating carriage for the sail head, is that free?
If the foil is still very stiff, check forestay for clearance, rigidity and lack of kinks. While you are checking all that lot you may find something else or see something not right!
Solving problems is about identifying the bit that is wrong first then finding out what the actual problem is. Good luck!
I had a lot of trouble with the top swivel on mine last year and stripped it down to re-grease it. But later discovered that the bearings are designed to run without grease (alternate stainless steel and plastic ball bearings) and just need frequent rinsing with fresh water.
The stiffness was due to corrosion between the stainless steel ball races and the aluminium housing. This caused swelling and excessive pressure on the bearings. Mine is an old Hood Seafurl system; I don't know if the more modern designs use grease or dry bearings.
Agree about not using grease on your Seafurl, but my manual says they should be treated to a spray of WD40 after washing out salt/dirt etc in fresh water.
I have not needed to use the WD40 yet, but do regularly thoroughly wash out the bearing races. My 18 years old unit still spins incredibly freely!
I have learned how to look after a Rotostay over the last five years, so it looks like you need to tell us what kit you have!
Neil
