Inflatable repair
mick
10 Aug 2001
Clyde
I have ordered online some 2-part adhesive to use in a repair of my PVC inflatable (Wetline). If I do a repair using single part adhesive, so I can use the dinghy now, is it simple enough to remove this patch at a later date in order to do a permanent job?
VicS
13 Jul 2002
If you use a adhesive that is specifically for PVC it probably contains a solvent for pvc. If that is the case it may not be possible to remove a temporaray patch with out some damage.
ostra4
11 Jul 2004
west yorks/Greece ionian
Most inflatables have a very specific and detailed repair procedure which must be followed to the letter to be successful .If you think you can use 2 part or one part It may be better to check you will be using right instructions as I dont think one will do for other and vice versa .If it was me I would check repair instructions and do job once even if it means waiting a day or two ..Good luck with it
