There wouldn't be any flames to seal the ends of bits of rope that I cut.
I watched that last night and was impressed.
We have an induction hob at home and I wouldn't swap it for anything. I hate having gas on board so I've got an origo spirit stove, but if I could swap it for induction I'd be happy..
In a marina with shore power it wouldn't be an issue ( yes I know I've posted about that on another thread ), but I'd be interested to see some real world calculations of the power needed to boil a kettle whilst underway.
Also, they fitted a very nice ( and no doubt expensive ) bank of li-ion batteries so they have the possibility to use more power from them and then recharge around the clock with wind and solar.
So apart from johnalisons issue above, I say if you've got the generator power bring it on![]()
Standard fitment to a lot of the big boats for quite a few years now. I had one in my house and the first night got very angry with it as it wasn't working...... wrong pans![]()
I was thinking more about the whole project, rather than just the hob. On the surface, it looks pretty decent. The batteries provide good power. He talks of being able to take the batteries down to 80% discharged, that's technically 640ah. It's going to take some serious charging equipment to get them charged back up the next day, with a little bit of an allowance for inefficiencies and power usage during the day you could be looking at 10kwh or more. My 260w of solar gives yields around 1kwh on a nice sunny day.
Something that doesn't get mentioned in the video is the cost of the batteries. Well, they are £1199 each, so that bank of batteries cost £9592 !!
My batteries cost just over £100, will a Lithium one last 12 times as long ? I currently use 2 x 4.5kg bottles of Calor butane in a year, onboard for the whole year, plus a few quids worth of electric for boiling the kettle in the marina. What about the grill and oven ?
All in all, the tech is interesting, but the economics just don't stack up and i can't see the big deal about carrying some gas onboard. Is it really hard to source as you travel around ? My locker hold four bottle, i could go two years without a refil![]()
Presumably if your boat's electrical system is man enough for electric cookery, you'd just use a standard 3kW domestic kettle rather than putting a stovetop one on the hob.
I just bought a smaller 1kw kettle and it is enough for two cups and takes approx 2 mins to boil. I can work out the exact power consumption later and report back.
1/30 kWh by any chance?
(Ok, only kidding. I know that if 1kW is the output power, the input will be a bit more).
Ok well the kettle draws 60amps when in use and takes 2mins to boil half a litre. The hob about 90 but it is intermitant as it varies the heat. Both are measured at the Link 2000 which is accurate in my opinion. I'll take a closer look at usage over the coming days as we cook and see roughly the power consumption in real life.
