zoidberg
As part of my refurb'ing of a tough ould Cutlass27, I'm fitting an inner stay on which to hang a 'Solent' jib on a furling foil for brisk breezes. I reckon this will be about 95%-100% of the inner foretriangle, and I'm told by sailmakers it's 'up to me.'
I'm now thinking about where provision should be made for sheeting of this furling/reefing jib. There are no conventional tracks on the coachroof - the original design had but one headstay, and simple tracks just inboard from the toerail.
There ARE a pair of deckeyes on the coachroof each side, bolted through at ~293cm and ~315cm respectively from the new tack point, and 43/55cm off the centreline. The mastfoot is 250cm from that tackpoint.
That gives notional sheeting 'angles' of ~8 amd ~10 degrees respectively.
I could clip sheaveblocks onto those deckeyes, or some arrangement with Low Friction Rings.
I could even fit short transverse tracks - I have the track and cars spare - but perhaps wouldn't want to do that until I had 'pinned down' the sail dimensions and sheeting requirements.
What does the 'hive mind' think about creative use of those existing deckeyes?
