William_H
I relaunched Howzat on Monday afternoon. No 2 son helped put the final antifoul pant on the bottom on sat. A horrible job due to trailer structure rollers etc. I jack the trailer up by about 15cms to give more room underneath.
So just about to drop it down off the blocks after being up all winter. Though I had better check wheel bearings and I found I could not turn one wheel. Got the wheel and bearing off stuck up with rust and gunk. I had a replacement (very old bearing) which I banged. Seems OK 0nly have half Km to the launch ramp max 40kmph.
Ok got the boat to the club ramp with no 2 son's help. Tide was low so ramp seemed steep. Fiddled for ages trying to get the safety chain off the bow attachment. The load of the winch wire jambed it all up. Finally saw the obvious to put winch hook onto bow rail while I disconnected safety chain. I let her go and she unwinds the winch cable as she slides in. I leave the cable out for next time. Poppa (ol'will) is getting a bit confused in his old age
Get ready to raise the mast. Damn forgot to fit wind pointer. Finally got that on despite loss of a little clamp on the pointer post. I hope it survives up there.
I always have trouble getting CB down. It is like a dinghy CB with a foil shape board through a foil shaped hole in the hull at the bottom of a rectangular case. In the process of raising and dropping a few cms until it jambs the old 3 strand polyester rope parted. I tied a knot in the break and finally got cb into it's hole. The knot stopped the CB going down so I cut the rope at the knot. CB went dwon with a huge crash. Fortunately this has happened before no damage. The rectangular shaped CB top is a close fit to the case so water in the case must be squirted out by the larger top as it goes down spraying water around a bit inside. CB stays down all summer.
No problems sailing out of marina. (I hate engines) Back at mooring I have lost skills in picking up buoy over winter. Boat stopped short and we went around only banging one other boat slightly. Granny SWMBO had kindly rowed the dinghy out to the mooring to bring us home.
Now I haven't mentioned 4yo grand son who was on board. A defiant at times little fellow. I had told him not to play with winch handle. (the sea gobbles them Up I told him) so While we were packing up he had the wijnch ahndle in the jib winch. I made a grab fro it and yes you guessed it, it jumped over board. Fortunately granny was still in the dinghy and managed to retrieve the floating winch handle. Yes they do float.
So finally back to the beach. Who has got the keys. We use a electric scooter as a dinghy tow tractor to take dinghy home. UhOh keys left locked inside inside the boat . no problem walk home get spare set of keys and finally get home put trailer and dinghy away. For another season.
I try to maintain habits on the boat like always leave the keys in the 2 padlock joined together so you naturally put the keys in your pocket. All these habits get disconbobulated after a winter boat at home.
Yes went back yesterday found the original keys fixed up this and that. I had a list of more jobs to do. So now all set for Sunday. Sailing is all about crisis management. Fortunately nothing serious this time ol'will
