In the Mediterranean: winter break in the marina – who uses heating and dehumidifiers?
Do you use heating and/or dehumidifier in winter Med ?
  • Nothing
  • Heater with > +5 Deg.
  • Heater with > +12 Deg.
  • Dehumidifier 45%
  • Dehumidifier 55%
  • Dehumidifier 65%
Results are only viewable after voting.
Skipper Felice
24 Sep 2023
Italy - Switzerland
In the Mediterranean region (Spain, France, Italy) normal temperatures range between +5 and +15 degrees in winter.
Is it necessary to heat a motor yacht or operate an air dehumidifier during this period?
If so, what settings should be used?
The temperature here rarely drops below freezing and a typical "cold" night is still only 4-6 degrees. Even in these "cold" conditions, my experience is that the temperature in the engine room doesn't usually drop below 10 degrees and the interior (lower deck) of the boat is generally a few degrees warmer than this. I don't use dehumidifiers or heaters and in +10 years have never had any problems with damp or corrosion. I do try to find time to run the engines, generator and interior heating (reverse-cycle AC) for short periods a couple of times a month just to keep fluids and air circulating and ensure everything remains in working order.
I never bothered with anything.
What I did do is periodically run up all the systems, try the seacocks
On occasion when we did sleep aboard the reverse cycle AC seemed to warm it up .
I think the sun in the Med on bright days and wind was enough to circulate the warmish air / cause draughts when we were absent in the off season . Employed a guardian to regularly clean the exterior who could also open it up .
Never had any damp or mould issues .
Ok - I think this is very ok for Liguria and the region of north Italy. I try to handle it the same way.
I've found that it does need a blast of heating every now and then but generally what Porto says is correct in my opinion.
Even on the coldest days (in Liguria), it never really got too cold inside. I've had snow on the boat twice in 12 years and by 11am it had all melted.
