MagicalArmchair
We had our shakedown sail over last weekend, it was a stunning day in Poole harbour and we had a lovely sail.
Suffice to say Mirage hasn't been sailed much in the last five/ten years before we purchased her. The wind instruments point somewhere the wind isn't, the echo sounder does not reflect how much wet stuff is under the boat, and the furling gear (which is this: http://www.seldenmast.com/files/595-063-E.pdf) is stiff as a board.
I kicked myself that I had put that sails on before greasing the whole system (I had the perfect conditions to put the main on so leapt at the chance), as it was very stiff to unfurl, and very (very) stiff to refurl up when heading back. On both unfurling, and refurling, I rounded up into the wind as per Seldens advice:
The sails are brand new (lovely) Kemp Vectron (Dacron with Vectran weaved) sails, so they are quite thick and stiff. Reefing the sail away was so stiff that the continuous line (which I suspect is too skinny anyway (there is a replacement on board that the previous owner never had spliced on)) kept jumping out of the furling winch on the front of the mast. I wanted to keep some tension on the Outhaul to make sure we packed it nice and tight, however, even with the outhaul completely loose (and the sail flogging - I did make sure half way through reefing I clamped it off and did a few turns to try and pack the sail tighter), it was tough going, with me needing to keep tension on the other end of the continuous line to stop it leaping out of the reefing winch on the front of the mast.
Clearly I need to drop the sail, grease the whole lot and then raise it again, there goes a day of sailing, boo, as reefing being that hard is simply painful and dangerous in a blow. I made sure the halyard wasn't too tight when I put the sails on the luff groove, and that the boom was perpendicular to the mast when furling away.
Was my reefing technique right? The below, very good, article states:
How to: A Trouble-free Furling Main
Which directly contradicts Seldens own advice.
How do you do it? Any advice on getting my furling system to play nicely? Should I just go sailing and it'll free up from use eventually? (unfurl, refurl, unfurl, refurl, rinse, repeat) Or is that inviting a seized system and disaster?
Hi Mark,
We would advise for you to always furl the sail head to wind, this is so that the sail isn’t full, therefore taking the load off of your furling mechanism.
As well as making your furling and life a lot easier it will also help to improve the longevity of your system.
I hope you find this information to your benefit.
Kind regards,
David Richardson
Sales Co-ordinator
Seldén Mast Limited
Put the boat on a starboard tack, with the wind slightly forward of the beam. That way, the sail will feed in and around the furler; on a port tack the full height of the sail would be dragged over the sail groove in the mast, adding friction.
