Sammy Lou
I’m having problems with my clipper depth sounder. The display is showing depth readings with a wide range and will not settle nor agree with my estimation of chart depth + tide height.
It’s not a major issue as the boat is a lift keel southerly but if it is fitted I’d like it to work.
The unit was working fine last year but since then the hull has been coppercoated and I’m wondering if anyone has any experience of coppercoat ‘interfering’ with depth transducer readings.
The unit is a clipper duet and the transducer is an in-hull type fitted in a vertical mounted, plastic, oil filled tube bonded to the inner side of the hull. The transducer is located forward and close to the paddle wheel.
Ever since the boat going back in the water the reading has been ranging wildly and indicating a range of depth greater than actual. At first I thought it was just a connection somewhere and I found the co-axial wire badly joined. From here I have ended up replacing the transducer and re-joining the cable via a proper co-ax joiner but the readings are still all over the place but not so far out. Now it seems to be worse in shallow water than in depths.
I’ve read the manual, adjusted keel offsets and gain but do not know what else to do.
Is there anything I’ve missed? Has anyone else experienced a change in behaviour after coppercoat application?
Thanks for any advice.
