imray charts
ayjay
17 Oct 2003
My pencil (if you will pardon the expression) doesn't like imray charts. Is there a better alternative?
Solitaire
25 Jun 2001
Southampton
Use a 2B pencil. Which is what you should use on a chart anyway. 2B's work fine on Imray and are easy to rub out - softer lead. HB's are too hard and will score thru the chart.
cliff
15 Apr 2004
various
Navman 5600 or similar - no more problems with pencil on the chart. or laminate the chart and use a chinagraph pencil.
ashanta
28 Apr 2003
I use Imray and B2 pencil. You are probably using a HB which is too hard does not make much of a mark. A B2 is also easier to rub out than a HB.
Regards.
Peter.
Viking
23 Jan 2002
Ålesund, Norway.
Re: Erase / rubber
Everyones correct use a 2B pencil. But also use a very soft erase (a rubber, particularly a used one,can be very messy /forums/images/graemlins/blush.gif ) a hard erase can damage the chart surface.
