pcatterall
We all know that these little fridges have their limitations, only cooling to X degrees below ambient and using a lot of juice.
Regarding the power consumption; ..... Once the cooler has reached the lowest temp it keeps running ( and using power ) what if it were then to be switched off for, say, half an hour? the internal temp would not increase much and would easilly be reduced again with the next half hour of power.
I guess that there is a suitable device to just keep switching it on and off.
Of course you would have to set this timer to work when the desired temp was reached as I can see that introducing a thermostat would add complication.
