Pasarell
I put off changing my water pump impellor because it's so difficult to get at. I know that's dumb anyway - but am I going about it the wrong way?
Engine is a (Kubota) Hydromarine DM12 and the pump is on the rear right side of the engine, just forward of what I assume is the flywheel housing. Gap between the housing and pump face plate is about 2cm.
Just to add some spice I have to remove the bulkhead between the quarterberth and engine compartment to get at it and then lie down using my left (wrong) hand.
Gap in front of face plate means even the smallest right angle screwdriver I've found won't fit so I used long nosed plyers to undo the screws - from their condition what previous owners have done too.
Whole job took about 4 hours. Glad I did it as one of the fins had broken off and was being swept around inside the pump.
Everything I've read says I should be able to replace the impellor in minutes out at sea. I went into a marina to avoid the slight movements on my berth at the top of Southampton water and still took hours.
I imagine a Speadseal will help but am I missing something else?
Anyway engine now runs smoother, quieter and cooler.
All comments on how to make next change easier are welcome. There has to be a better way!
