zoidberg
There's a discussion elsewhere about trapping fragments of broken-up raw water impeller - something that has vexed a few. Here's some of the text. Any good ideas....?
KH - You need to find all the pieces. They are probably in the heat exchanger. Why? This blockage can contribute to engine overheating under high load, or high rpm. When the engine is running hard it is using the whole heat exchanger. Blocked passages prevent this.
EB - I will admit freely that I don't know much about these engines but.. It seems that if these impellers are prone to fail as this one has, shouldn't there be some sort of strainer prior to the heat exchanger to catch chunks big enough to clog up the passages? Or maybe the exchanger is easy enough to service that "it" serves that purpose.
WB - I've queried/suggested that to a very experienced 'Boat Rescue Service' engineer, who poo-poo'd it. He reckoned such would restrict the flow to the engine. I'm not so sure, as a coarse mesh filter could do that job without much restriction - certainly not as much as barnacles/mussels in the inlet - and we hear of many examples of impeller break-up part-blocking the heat exchanger.
EB - Just seems like it would be a low cost, and potentially easy to service device, certainly easier that taking the heat exchanger apart and poking out all the tubes. A course mesh strainer (which is all you would need if you are only interested in catching bits that would clog the exchanger) would not cause any restriction unless it was clogged with debris, which is precisely what you want it to do!
WB - There has to be 'something' that could be cannibalised, with a clear enclosure, which would do the job.
