vas
are you absolutely sure that while you were tinkering with this fuel gauge, you didn't also move about something else that had foul contact and fixed it without knowing? I mean, if you undo this cable off the fuel gauge, will everything go haywire again?
odd!
re thick cables, trying to sort an issue with my galley fridge power dropping, I went silly with some 10mm2 cables from the breaker around 5m (10m return). Then realised there's no effing way to crimp an normal spade terminal that would fit the fridge danfoss controller!, ended up getting 100mm thinner cables with properly crimped spades and a chock block. Later realised that it's due to tired/wonr breakers so winter project is replacing (most?) these lovely 70s breakers with modern ones. Once I find BLACK breakers at reasonable cost...
V.
odd!
V.
