11harris11
New Member
1994 5.8l fi ford engine/omc petrol
The problems seems to be electrical, I turn the key to the first position and even before cranking the engine the spark plug coil is activating and fuel pump relay is rapidly turning itself on and off? Shuld higher and low pressure fuel pumps remain on when engine is started?
Before the engine was running fine, fuel pumps would prime and turn off in the ignition position, now they stay off in the ignition and starting position.
Also checked the fuel pumps and they are working fine along with their relay. It seems to be the switching wire that is jumping between 6 and 12v
Trying to get my head round this is a nightmare!
Any help would be much appriciated, thank you
