sailorman
what would you choose
sterling or adverc or another make
I'd be looking at Balmar for alternators and controllers. I've always had excellent service from these products.
Go for a Balmar they offer ramped start up function so little load on the belts when putting charge into batteries that have been run down...
Both the Sterling and Adverc boosters have a ramped start-up, so that's not a reason in itself to choose Balmar. I'd agree that the Balmar equipment is well made, but it's very expensive and is overkill for many boat applications. The Balmar high output alternators are basically only Prestolite Leece-Neville units painted white, and you can buy the base Prestolite units much much cheaper.
I agree they are expensive and as you say the alternators are based around a standard alternator, however one of the things that really attracted me was the plug and play aspect everything comes well documented with wiring harness that is designed to simply connect to engine and control panel so it can all be fitted within an hour or so. Perhaps you do pay over the odds a little but I felt it was worth it particularly when long term cruising away from marinas and that I think is where the need for a well found charging system matters.
I wouldn't fit any kind of booster. The Sterling effectively puts a full load on the alternator which fools it into thinking that there is a major drain on the system and as such the standard regulator works at full current. This sucks all the energy out of it to provide the "boost". The problem can be that if the alternator is already an "old" alternator it may die fairly quickly.
I would buy a new "hot rated"marine alternator and an external regulator, and keep the old alternator as a spare. Whatever you do buy the battery and alternator temperature sensors - especially if you have AGMs as the alternator will be loaded much longer and harder than FLAs.
Not strickly true, ......
