If anybody needs an O ring.........
MoodySabre
24 Oct 2006
Bradwell and Leigh-on-Sea
A judicious purchase on ebay has acquired for me the items I wanted - and several, nay many, hundreds more :o
Metric and imperial. Three boxes originally from RS. Box 1 has 382 in BS sizes - and there are two other boxes :eek:
Not bad for a tenner :cool: Feel free to ask because the beneficiaries of my will won't be interested in them :D
coincidentally, this is what I need.....
this is what I need-
Type: O-Ring
O-Ring Type: Standard
Width: 1/16"
Actual Width: .070"
Inside Diameter: 5/16"
Actual Inside Diameter: .301"
Outside Diameter: 7/16"
Actual Outside Diameter: .441"
Material: Buna-N
Durometer: Hard
Durometer Shore: Shore A: 70
Temperature Range: -35° to +250°F
or
Typ:e O-Ring
Width: 1/16"
Material: Viton
Durometer: Hard
Durometer Shore: Shore A: 75
Temperature Range: -15° to +400°F
or
Width: 1/16"
Durometer Shore: A70
can you help? :D:D
Hi Roger
I could do with some for the hand pump shaft in the loo.
Will see you at Fit-up to sort the size required if that is o.k.
Thanks for the kind offer.
Lisa - yes. That size is BS011 but I've only got 20 :D Is it urgent (can deliver to boat tomorrow) or wait for Fit Up or post to you. How many?
Clive - will empty my cockpit locker to make room for them :D
BRILLIANT! - Marc will be most pleased. :D You would not believe the moaning that I suffered last night while he lamented the lack of an appropriate o ring. Your posting was miraculous timing!
yes please post - will reimburse as appropriate. Will PM my address. Thanks Moodysabre!
MWAH!!
I would like several large ones as my valued Customer is shafting me beyond the durability of my current sealing arrangement.
MWAH!!
Lisa , just in case Marc (or anyone else really) needs O rings , seals , bearings , etc etc etc and MS can't help with one or two ;) I have found the following usefull , www.bearingboys.co.uk , I used them when I serviced my road trailers wheels/bearings .......
First off, thanks to Roger for the o rings he sent to Marc - much appreciated.
However, I hadn't told Marc that Roger would be sending them and in the meantime or ordered two. See the result in the picture.
I didn't know what he was ordering and I was utterly gobsmacked at the price when I saw the ridiculously teeny items that actually arrived. :eek:
[/IMG]
[/IMG]
20p's worth.
Get a grip of the bloke.... any stockist for O rings, like this one in Dartford...
http://www.barnwell.co.uk/orings.html
Visited Beyond Reason yesterday for battery charge and check over. Found water in the light that's attached to the horseshoe lifebouy. Suspected O ring was to blame so took it off and visited chandler's for replacement. They didn't have one the right size.
As I'm an idiot, I didn't measure it or anything useful like that. It's still on the boat. What should I do, collect it next time I visit boat then send it to you? Not sure I would know how to measure an O ring.
Fill the groove with Vaseline and screw back together using the old O ring until the new one arrives....... mine tend to last from year to year using this method.
