fergycool
Hi,
My raw water pump bracket is a rubbish home made affair with a pedestal Jabsco pump. To tighten the belt you need to slide the pump upwards on a bracket then tighten two nuts. Needs three hands!
I'm thinking of making a bracket to hold the pump in one place, then use a idler wheel tensioner on the outside of the V belt to adjust the tension in the belt.
Is that going to be OK? I need a idler wheel on a screw to tighten it. Do such things exist?
Thanks!
Ferg
Thanks!
Ferg
