martinwoolwich
A catalogue of problems - but still trying to find an answer.
I have an ICS Nav6 Pro that doesn't work! It only worked once, when first fitted - after 3 attempts - when the boat was based on the River Thames.
On that install the company (who shall remain nameless but were completely useless and charged me £800!!!!), fitted it as a stand alone device. I was so frustrated with the first company that I got another one to connect all the NMEA stuff together with my onboard SIMRAD CP42
Since then it's not worked. At first I thought it was 'cause I was on the Thames - even though it had worked the first time - and wasn't a pressing problem anyway because of the boats location. I have now moved it down to the Solent and still no Navtex information - All the NMEA stuff seemed fine and the screen showed both frequency icons and no errors anywhere.
Once in the Solent (this was April) I rang ICS who took me through various checks whilst I was sitting on the boat in front of the thing. Their only suggestion was that the Simrad was sending out too much data and was conflicting with the working of the NAV 6, but they weren't sure this was the problem as they had not heard of this problem before. So I turned the Simrad stuff off, waited 4 hours and still didn't make any difference. Two days later the screen failed anyway!!
Someone told me this was a common fault on early production runs of the NAV6. So got in touch with my second company to remove said device and return to ICS.
Call after call and some four months later, they still hadn't done it. Eventually, I got yet another company involved who disconnected the whole thing and sent it off to ICS for repair.
ICS replaced the screen and also did a firmware upgrade (and I assume fully tested the unit as working)
NAVTEX was re-installed last week. Went on boat this weekend and same problem. All NMEA stuff working so as a repeater screen it's great. As a NAVTEX device it's non existent - but everything on the screen looks like it should be working.
I even did a factory re-set again to check that the installers hadn't done anything funny.
On the basis that it's already been back to the manufacturers for a repair and firmware upgrade it would seem reasonable to assume that they tested everything and the main unit is working OK. On the basis that I have both frequency icons at the top of the screen it implies the aerial is OK. On the basis that I have the same fault whether my Simrad kit is on or off that doen't seem to be the problem.
Does anyone have any suggestions what to look at next?
I know the correct thing is just throw the bloody thing away, but it's now cost so much money and time - I'd really really like to see it working.
Serious suggestions gratefully received.
