ICOM MA-510TR and Yakker
Petronella
29 May 2004
Scarborough Marina, Australia
Hi
My new ICOM MA-510TR outputs AIS data via pins 7 (+ve NMEA) and 8 (-ve NMEA) to my plotter. They are the only pins used. It works fine.
My Yakker is powered from the battery (12V and GND connections) and also has AIS pin 7 to the Rx connection and AIS pin 8 to GND connection (so battery GND AND pin 8 to GND connection on Yakker) . It works fine.
BUT ... when I connect them both into 7 and 8 together only the plotter works and I no longer see any AIS sentences coming out from the Yakker to my tablet.
I thought NMEA could have several listeners. Am I wrong?
Will also contact Yakker but has anyone seen similar?
TSB240
17 Feb 2010
Are you not connecting two "talkers" or outputs to one " listener" the plotter input? Is the yakka a listener?
Petronella
29 May 2004
The AIS unit is the "talker" and the plotter and the Yakker are "listeners". The Yakker is connected via its "Rx" connection. It's true the Yakker then outputs a WiFi signal but as far as the AIS unit is concerned the Yakker is a 'listener".
