Mark-1
I have a icom-m411 that doesn't receive transmissions unless you turn the squelch to the point where background noise kicks in.
Eg: Turn squelch to the point where the noise is suppressed, transmissions not heard and the 'busy' text never shows. Turn the squelch to the point where the noise is constant and 'busy' text permanently visible and transmissions are heard clearly over the noise.
I've swapped in different sources of transmitters (Marina + Handheld) + the boat Antenna and a 2 foot bit of wire I plugged in the back. Behaviour is identical regardless of transmitter or antenna.
It's long out of warranty, and possibly destined for the skip, so I won't be getting a pro involved but I'd like to fix it myself if possible.
What's wrong with it?
TIA.
TIA.
