I need a 12v lead for an alfa r36
SteveSarabande
3 Apr 2012
Solent
I just got an Alfa r36. I want to keep the 240v option, but need a 2nd lead to wire into the boat electrics.
Anyone got any links for one, or maybe the bits to make one.
Maplins will have the plug, it's 2.1mm/5.5mm or maybe a tiny bit shorter, but the 5.5 one fits.
http://www.maplin.co.uk/p/maplin-21-x-55mm-dc-power-plug-hh60q
Same size as a lot of cctv power which might be easier if you don't want to do a fiddly Solder. Mines been fine straight off the boat batts but if you want stabilised power something like this is dead handy on the boat...
http://www.ebay.co.uk/itm/DC-Boost-...992?pt=LH_DefaultDomain_0&hash=item565ffe6ce0
Hunt around on ebay there will be a UK supplier. Also, maplins do a 1A self reseting fuse to keep the magic smoke inside if you get it wrong.
Edit - I have a few of these ones...
http://www.ebay.co.uk/itm/DC-DC-Con...al_Components_Supplies_ET&hash=item3cd7cc065b
I bought the Maplins plug and associated cable (just two core wire with a socket on the end to take the plug). Wired it direct (via breaker) to the boat electrics. Have had it wired up for a year now and not had any problems. Seems to have coped fine with voltage fluctuations on the boat.
