I just spotted this
Norman_E
15 Mar 2005
East Sussex.
I have a couple of Dimplex 500 watt convector heaters with a frost watcher thermostat. They are now quite expensive to buy, but are ideal as caravan heaters, and as heaters on board a boat with shore power, to prevent condensation. The Dimplex Coldwatcher heaters now have a list price of £90 and can be bought for about £59. https://www.dimplex.co.uk/product/multi-purpose-heater-05-kw-coldwatcher
I just found this for £14.95 https://www.ukhs.tv/500w_Frost_Watc...598281601933266413707832108007810498736344126 and think it might be an acceptable substitute.
Worth noting the Dimplex has a metal sleeved element - like a kettle element - that runs at a relatively low temperature - below red heat - so is not a fire risk.
I guess this much cheaper one may be an exposed red hot wire element.
Up to you whether that bothers you!
Those are good too, particularly at that price, though a bit heavier and you would need to check that the thermostat goes down low enough to use it for frost prevention. I have a bigger oil filled radiator where the thermostat only goes down to about 15 degrees C.
Looks good but much more effective condensation removal by a dehumidifier and a lot cheaper to run as they only marginally heat the boat.
I use a dehumidifier and a 300W tubular greenhouse heater on a separate thermostat for the engine bay area. With the larger oil-filled radiator type, check the instructions/specifications; I looked at a modestly-priced example and found they said ‘Do not use unattended’.
We have to frost-protect our carpet cleaning truck-mounted machines, full of thin copper heat exchangers, etc, and we always go for oil-filled rads - they run at much lower (element) temperatures, but are capable of 3Kw if needed.
