RIMCOas01
Did not post earlier as boat taken out/- tested for several hours by 2 (yes 2) VP service engineers on sep. days. They are stumped ... so now the post.
Toward the end of the season the boat started to have problems "getting it up" ... the revs I mean. Regularly serviced by the "pro's" ... now run 473 hrs, last full service with valves, etc at 428hrs.
Regardless of conditions, or hours of running .... when the revs drop below 800 I have to coax them up again to the normal 3400/- 38knot limit.
IE. Advancing the throttle increases the revs to ca. 1400 and then they just drop off. Slowly throttling up, backing off, up again, backing off again , etc, etc ... and then eventually at some point it seems the engine says " Oh, okay then ... here we go" ... and I am off.
And everything is perfect .... until I have reason to drop the revs below 1400 or so and the problem (and solution) is repeated.
2 VP engineers have had the boat out and cannot figure out the problem ... starts first time, filters and belts replaced earlier in the season and still okay, no water in either primary or secondary filters, no electronic faults diagnosed, no "blowing", no water ingress/- oil is clean, compression A1, injectors fine, hydraulics & cables fine, temperature readings fine, oil pressure fine, voltage fine, kompressor fine, ...
So ... what is the cause ... it's cost me already for their time ... without a solution being found.
PS . She is now high and dry having her bottom scrubbed ... neglible growth and outdrive mechanically A1
M
Apologies if post a bit long ...
M
