ProDave
Sailing today, with a reef in the main sail, a part broke off the boom. It's the fitting on top of the aft end of the boom, onto which the topping lift and the reefing line was attached. I now know that should only have been used for the topping lift, and the reefing line should have been secured to a different fitting. (the joys of a second hand boat that didn't have the best of previous owners)
The reefing line is now attached to where it should be, and topping lift secured temporarily but now need to make a permanent repair.
I first need to find the correct name for the now missing part, It's a U shaped SS bit of metal that I would describe as a "saddle" (as in it looks like an electrical conduit saddle fitting) No doubt in marine terms, it has a completely different name.
Of course I don't have a picture of the missing part. An image search has found this picture:
The part I am talking about is riveted onto the side of the boom in the above picture. Ours was riveted onto the top of the boom. I need to know the correct name of that part so we can buy a new one.
The rivets pulled out of the mast and the part is lost. To replace it the choices seem to be drill out and use larger rivets than before, or since it is near the aft end of the boom we recon we can get in there to attach a washer and nut, to nut and bolt the replacement on. Thoughts on that please?
