trouville
N/A
I just bought for £34.29 a "HOYOMA" 200w constant 400w maximum inverter 12v- 230v out.
I want to use it to charge electric razor, battery drill,PDA, Laptop,printer It wont do any of those things!!(im not taking the printer with me this time)
When i plug in the printer it starts up but wont print?
When i try to charge my old laptop it remains at 93%?
When i try the transformer for the drill which needs just 0.38 amps/220v it cuts out
when i try a small sony radio it dosent go at all on transformer?
Stereo system which draws 1.2 amps on full volume (loud!) and CD player in use and will run without battery just from my 18w solar panel! (i have to adjust the volume to keep the voltage down!) wont run at all from its 230v to 12v transformer (max 1.2 amps)???
When i plug in a neon lamp cuts out
When i plug in a 40w lamp it lights up but the inverter "screems" loudly
Whats wrong with it???Its the same system as the others sold for use aboard.today
I have had for 15 years or more a 200w inverter that weighs 6 LBS and has a large transformer, from that i can run all the above plus a normal electric drill or small sanding machine!! and have done once when i dident want to start the gereator Never a problem ever?? (i cant go down to get it as i havent the time and would cost me 200Euros for petrol--not practical)
So what is wrong with this "compact" modern inverter????? At the moment its just a useless lump!
Is there anything i can do to get it working??? Or must i look for another model??
HELP!!!!!What can i do???????????? Where can i buy another large model that works???
