I appear to be travelling in reverse on plotter!
Thepipdoc
13 Jun 2009
Torquay, Devon/River Dart
I have a 2 Raymarine plotters a RC530 and a RL70C both of which show that I'm travelling in reverse! When I opt for the "Course Up" or "Head Up" mode I move towards the bottom of the screen. This is very confusing as I'm sure you can imagine.
Even the boat symbol that Raymarine use is the wrong way around so it appears that the bow is following the stern when I'm moving forward!
I'm sure I've done something wrong on both plotters, but can I find the solution to the problem? Hell no!
Someone please tell me how to correct this.
(please don't say turn the plotters upside down!)
Thanks.
MYAG
6 Dec 2009
Med
Thanks.
I have heard of this problem before and generally it is to do with the Fulxgate Compass being disturbed/needing calibration. There might be a poor connection, things may have moved or you may have unknowingly placed something metallic near the compass without realising etc etc. Either way, check the connections and recalibrate. If you dont have the manual the Raymarine website will have the info. Its a straightforward procedure.
Solitaire
25 Jun 2001
Southampton
Thanks.
Your fluxgate is fluxed!
This can happen and it will need replacing.
noelex
2 Jul 2005
That would be silly
You need to travel everywhere in reverse.
Thanks for both replies.
Now I'm going to ask another silly question. Where/what is a fluxgate compass?
They look like this:
Usually mounted near the centre of the boat. There will be a wire from the autopilot leading to it
Thepipdoc
13 Jun 2009
When your in north up are you traveling north or south,not on the plotter, the boat.
I think that when in North Up I'm travelling north. I may be wrong with this becuase this is from memory.
It will be tucked away somewhere on the boat. What boat is it? It can been "hidden" anywhere. You do have autopilot?
I do indeed have an autopilot.
MYAG
6 Dec 2009
Med
aquapower
22 Jul 2009
Try disconnecting the auto pilot from the plotter, the plotter should show you boat position and track, this will eliminate the fluxgate.
Thepipdoc
13 Jun 2009
According to the Raymarine FAQ's (Thanks MYAG) the following readings should be found when carrying out a check of the Fluxgate compass.
The first 3 are exactly as they should be but the 4th test says SCREEN to blue. Is this a typo for Green or is SCREEN correct and it means earth or something simmilar?
I'm hoping its a typo because I get an open circuit when I check GREEN to BLUE and this would confirm beyond doubt that the fluxgate is 'fluxed" ( to use a previously used phrase)
1.Red to Green 4 ohms Measurement is taken between the two colors
2.Red to Yellow 4 ohms As above
3.Green to Yellow 8 ohms As above
3.SCREEN to Blue 8 ohms (this is what I should get but instead I have an open circuit when checking GREEN to blue)
MYAG
6 Dec 2009
Med
It is NOT a typo.
"SCREEN" is a terminal named on the SmartPilot. You will have 5 possible wires to test. BLUE, YELLOW, GREEN, RED and one called SCREEN.
Connect your meter from SCREEN to BLUE. You should see 8 ohms.
Connecting GREEN to BLUE is meaningless.
Follow the rest of the troubleshooting guide.
MYAG
6 Dec 2009
Med
